.....anderes Magazin ,andere Werte...allso immer locker bleiben
Specs & Performance
Vehicle
Year Make Model 2012 Porsche 911 Carrera S 2dr Coupe (3.8L 6cyl 7M)
Vehicle Type RWD 2dr 4-passenger Coupe
Estimated MSRP $105,000 (as tested)
Drivetrain
Configuration Longitudinal rear engine, rear-wheel drive
Engine type Naturally aspirated, direct injected flat-6, gasoline
Displacement (cc/cu-in) 3,800/232
Block/head material Aluminum/aluminum
Valvetrain Double overhead camshaft, four valves per cylinder, variable valve timing + lift on intake valves
Compression ratio (x:1) 12.5
Horsepower (hp @ rpm) 394 @ 7,400
Torque (lb-ft @ rpm) 325 @ 5,600
Fuel type Premium unleaded (required)
Transmission type Seven-speed manual
Transmission ratios (x:1) I=3.91, II=2.29, III=1.55, IV=1.30, V=1.08, VI=0.88, VII=0.71
Final-drive ratio (x:1) 3.44
Differential(s) Mechanical limited slip
Chassis
Suspension, front Modified MacPherson strut, coil springs, elctrically adjustable dampers, active stabilizer bar
Suspension, rear Multilink, coil springs, electrically adjustable dampers, active stabilizer bar
Steering type Electric speed-proportional power steering
Steering ratio (x:1) Variable: 12.25 to 16.6
Tire make and model Pirelli P Zero Nero
Tire type Performance front and rear
Tire size, front 245/35ZR20
Tire size, rear 295/30ZR20
Wheel size 20-by-8.5 inches front -- 20-by-11 inches rear
Wheel material Alloy
Brakes, front Ventilated 13.4-inch carbon-ceramic rotors, six-piston fixed calipers
Brakes, rear Ventilated disc 13-inch carbon-ceramic rotors, four-piston fixed calipers
Track Test Results
0-60 mph, mfr. claim (sec.) 4.3 manual; 4.1 PDK, Sport Chrono equipped
Fuel Consumption Fuel tank capacity (U.S. gal.) 16.9
Audio and Advanced Technology
Stereo description Nine-speaker, 235-watt six CD/DVD/MP3 AM/FM; Optional Burmester 12-speaker 800-watt system.
iPod/digital media compatibility USB, Standard Bluetooth audio
Bluetooth phone connectivity Standard
Navigation system Standard, 7-inch touchscreen
Parking aids Optional front and rear parking sensors
Dimensions & Capacities
Curb weight, mfr. claim (lbs.) 3,075
Length (in.) 176.8
Width (in.) 71.2
Height (in.) 51.0
Wheelbase (in.) 96.5
Track, front (in.) 60.6
Track, rear (in.) 59.7
Seating capacity 4
Trunk volume (cu-ft) 4.76
GVWR (lbs.) 4,034
Warranty
Bumper-to-bumper 4 years/50,000 miles
Powertrain 4 years/50,000 miles
Corrosion 10 years/Unlimited miles
Roadside assistance 4 years/50,000 miles
Collapse Advertisement
Related Content
I
