Z06 mit E85 auf der SEMA
Im AMS-Portal wird eine Z06 von Jay Leno gezeigt,
die ausschließlich mit E85 betrieben wird.
AMS -> Artikel-Link
Hallo-gruen , ......
Sieht sehr geil aus. Die Felgen find ich Klasse.
Aber auch so ein 8,2 Liter V8 mit 600PS hat was Yeeah!
MfG Olli
[Bild: CIMG4531.JPG]
respekt ..................... huldigen huldigen huldigen
jogi
autoteam-eppingen.de
MfG Olli
Was jucken die 600PS? Feixen
Die 793 NM ohne Kompressor oder TDI, das hat was Yeeah!
Meeeeeeeeeeehr hier: Jay Leno's 600 HP E85-Powered Corvette C6RS Revealed Before SEMA Debut
Zitat:Jay Leno apparently was unwilling to wait for the new 2009 Corvette ZR1 and decided he needed to get his 600-HP swerve on a wee bit early. The humongously chinned one worked with the C6.R-builders at Pratt & Miller to design this -- a C6RS -- a Corvette inspired by both the Corvette Z06 as well as the racetrack-ready C6.R. To all this, Leno added his own little touch of corniness -- the ability to run it on the ethanol-blended E85. Leno's alternative-fuel supercar is powered by a custom and giant 8.2-liter (500 cubic-inch) all-aluminum small-block V8 that pumps out approximately 600 horses and 585 lb-ft of torque. On the outside, the wider front and rear fenders and a wider rear fascia with an integrated spoiler on top combine with the racing-style diffuser and the waterfall hood with venting show some clear indications of C6.R inspiration. All we know is we want to drive this more than the Leno-inspired Ecojet concept car from last year.
GREEN AND MEAN: JAY LENO'S E85-CAPABLE Z06-INSPIRED C6RS CORVETTE BOASTS 600 HP AND ALTERNATIVE-FUEL CAPABILITY
LAS VEGAS - "Tonight Show" host Jay Leno's predilection for performance cars is no secret, but many fellow enthusiasts may not know that he is keenly interested in alternative fuels. To prove that red-blooded power mixes easily with a touch of green, Leno partnered with Pratt & Miller - the engineering company that builds and campaigns C6.R Corvettes - to develop a modified Corvette Z06 that is capable of running on E85 ethanol. It was unveiled at the 2007 SEMA Show.
More than merely a conversion of the stock LS7 engine to E85 capability, Leno's alternative-fuel supercar is powered by a custom, 8.2L (500-cubic-inch) all-aluminum small-block V-8 that pumps out approximately 600 horsepower and 585 lb.-ft. of torque.
"The C6RS is the result of an idea we hatched to prove that high-performance cars and alternative fuel technology weren't diametrically opposed concepts," said Leno. "I love the idea of having 600 horsepower at my disposal, but using a homegrown alternative to gasoline."
The engine is built around a custom aluminum cylinder block that was CNC-milled from a single block of billet aluminum. And while the cylinder heads, intake system and dry-sump oiling system are stock LS7 components, the engine - which has larger bore and stroke dimensions than the 7.0L (427-cubic-inch) LS7 - uses a one-off reciprocating assembly, including a forged steel crankshaft, forged rods and forged pistons. Katech Engines, the company that builds engines for the Corvette C6.R racing program, developed the engine.
The fuel system and engine control computer were modified to accommodate E85, and spent gases exit through a Corsa exhaust system. Supporting the 600-horse engine's power is a blueprinted and strengthened T-56 six-speed transmission and a high-performance Centerforce dual-friction clutch.
C6.R inspiration
On the outside, Leno's bad and black C6RS emulates the styling of C6.R racecars, with wider front and rear fenders and a wider rear fascia with an integrated spoiler on top and a racing-style diffuser at the bottom (the diffuser incorporates an LED-lit backup lamp). A C6.R-style waterfall hood front fender louvers, rockers and lower grille opening further define this special Corvette - and all of the car's front-end panels are made of carbon-fiber, including custom brake air ducts routed through the front fenders. With all of its body modifications, Leno's C6RS is 1.6 inches wider than stock.
The C6.R's - and production Corvette's - aerodynamically styled bodywork is designed to slice efficiently through the wind, which helps enhance fuel mileage.
The race-ready look of the car is enhanced with a quartet of BBS wheels that feature racing-type locking center hubs. The forged aluminum 18-inch front wheels and 19-inch rear wheels ride on Michelin P295/30ZR18 and P345/30ZR19 tires, respectively.
Adding authenticity to the car's custom bodywork was the involvement of Pratt & Miller. The company took on the task of crafting Leno's Corvette into a street-going replica of the racecars, which included installing or fabricating a host of unique components, including:
• A custom DeWitt high-capacity radiator with dual cooling fans
• A carbon-fiber ram-air induction system
• Carbon-fiber inner fender panels that vent hot air from the engine compartment
• Brembo brakes with six-piston mono-block calipers in front and four-piston rear calipers
• Dyna-Mat used throughout the cabin and chassis to reduce interior noise
While the exterior and drivetrain were inspired by the racetrack, the C6RS's cabin exudes luxury, with premium touches and enhancements from Genuine Corvette Accessories that include a two-tone shift knob and boot; leather-covered console armrest, parking brake handle and boot; an interior trim kit, racing-style pedal covers and more.
With its 600 horses on tap and domestically produced E85 fuel in the tank, Jay Leno's alternative-fueled C6RS is an all-American supercar that proves high performance and environmental consciousness go together like the Corvette and checkered flags.
[Bild: bannereur.png]
Leider muß er wohl, wie in den Anfängen der Motorisierung beim Drugstore tanken.
Ärgerlich dort wie hier.
Zitat: BY TPSREPORTS AT 12:29 PM
E85 is a joke.
There's only one E85 pump in all of Los Angeles, at least according to this web site:
[e85vehicles.com]
BY ANDYDUNCAN AT 12:51 PM
@TPSreports: Actually, I work in Brentwood, and that pump isn't operational yet, so it's really Zero E85 pumps in LA.
haarsträubend , .......
Jay Leno fährt nicht tanken, er lässt tanken - oder er lässt den Sprit von der Tankstelle zum Auto bringen. Großes Grinsen
Ach so Großes Grinsen . Wahrscheinlich dreht er dann die Erde wenn er fährt.
Analog zu diesem "wie-heißt-er-gleich", der die Erde runterdrückt bei Armbeugen Feixen
Feixen Hallo-gruen , .....
Hier die weiteren Fakten über Chuck:
https://www.chucknorrisfacts.com/
Hier steht vielleicht noch mehr über den Wagen.
KLICK MICH
Mitte rechts auf der Site sind auch noch einige Pics.
Olly
[Bild: olly_sig.gif]
Technisch gesehen ist die Verwendung von E85 oder reinem Alkohol ziemlich unproblematisch. Im Prinzip könnte man durch höhere Kompression damit auch höhere Leistungen erreichen, aber in Deutschland kann man sich bei E85 leider nicht auf die höheren Oktanzahlen verlassen. Je nach Region und Jahreszeit können die sich nämlich dramatisch ändern.
Gruß, Till
  US C6 Z06 mit 600PS an Kenner zu verkaufen 993raser 0 1.119 12.05.2024, 20:42
Letzter Beitrag: 993raser
  Flecken auf der Bremsscheibe Ralf67 14 6.822 19.06.2023, 20:49
Letzter Beitrag: René K.
  Michelin Pilot Sport 4S auf C6 Z06 robstor 82 87.595 28.06.2022, 01:25
Letzter Beitrag: RomeoBravo
  Wechsel von C7 Z06 zu C6 Z06 Brui1000 21 13.838 14.06.2022, 09:22
Letzter Beitrag: Username
  Suche Gutachten für C6 ZR1 Felgen auf C6 Z06 Supercharged 12 9.446 02.08.2021, 22:12
Letzter Beitrag: Eisbär Lars
