Reifen
Taugen diese Reifen was oder sind die eher nix,billig sind sie ja Schnarchen
The Exclaim UHP is General Tire's Ultra High Performance Summer tire that was developed for the drivers of sports cars, coupes and sedans. While meeting minimum tread design standards to be "M+S" branded, the Exclaim UHP is designed to provide high levels of traction, response and control in dry conditions, along with superior hydroplaning resistance in wet conditions. We do not suggest Exclaim UHP tires be driven in near-freezing temperatures, through snow or on ice.
The Exclaim UHP uses a 2nd generation, ultra high performance silica compound molded into a directional tread design that features wide, solid shoulder tread blocks and a high-tech contour to combine responsive handling with dry traction. Its Double-V directional tread pattern enhances wet performance. Together, the tread compound and design help sweep water away from between the tire’s contact patch and the road to improve wet grip while reducing the possibility of hydroplaning. The tire’s internal structure includes twin steel belts reinforced by spirally wound jointless nylon on top of polyester body plies to combine responsive handling and cornering stability with high-speed durability.
General Exclaim UHP (Ultra High Performance Summer)
for 2006 Chevrolet Corvette Z06
Front: 275/35ZR18
Blackwall
Serv. Desc: 95W
UTQG: Treadwear: 380
Traction: A
Temperature: A380 A A
Price: $169.00 (each)
Estimated Availability:
In Stock
Optional Road Hazard Program: additional $20.28 per tire
Front:
012345678
Rear: 325/30ZR19
Load Range: XL
Blackwall
Serv. Desc: 105W
Traction: A
Price: $203.00 (each)
In Stock
Gruss Chris
[Bild: gtc17.gif]
Geschwindigkeitsindex W, wenn ich das richtig entnehme.
Sollte sich damit selbst klären Großes Grinsen
Ach oder sollen das Winterreifen sein?
Ich frage wegen: Ultra High Performance Summer
aber da steht doch 325/30ZR19
Gruss Chris
[Bild: gtc17.gif]
Serv. Desc: 105W, ok habs gesehen 168mph/270km/h
hat sich erledigt ,danke Birger
Gruss Chris
[Bild: gtc17.gif]
Ja, ZR bedeutet aber nur über 240 km/h. Erst nach dem Traglastindex steht dann ein Zusatz z.B. Y für 300 km/h.
Oben in der Beschreibung sehe ich aber immer nur ein W stehen.
Quelle: https://de.wikipedia.org/wiki/Geschwindigkeitsindex
Schneller Finger .... Prost!
Ich sehe das so.... GM spart überall wo es kann und wenn sie keine Angst vor einer Welle von Klagen hätten, würde jede Corvette das Werk auf diesen Billigreifen verlassen.
Ich persönlich glaube eine Corvette auf den Reifen kennt nur noch eine Richtung... bzw. zwei.... im Uhrzeigersinn und gegen den Uhrzeigersinn animierte C4
Großes Grinsen
Gruß Sebastian
Bypass Probleme kann man niemals mit derselben Denkweise lösen, durch die sie entstanden sind. Albert Einstein
Deshalb montiert GM ab Werk ja auch andere Reifen Idee OK!
Großes Grinsen
An meiner Vette wurde nicht gespart, wie kommst Du auf eine
solche Idee ?
Gruß Edgar
  Reifen in 19/20" für die C6 Z06 sto 12 2.556 08.07.2024, 21:22
Letzter Beitrag: sto
  Alternative C6 Z06 Reifen chevyman 292 185.436 20.07.2023, 21:34
Letzter Beitrag: vladiiiii
  Reifen aufziehen 335/25 R20 in Frankfurt/Darmstadt/Wiesbaden oder Umgebung Chiado 12 25.751 30.09.2021, 16:04
  C6 Z06 Reifen Mad11 67 36.167 04.02.2017, 12:26
Letzter Beitrag: corvettetotal
  Z06 Rad Reifen Kombination für die Rennstrecke 1080 11 14.519 08.01.2016, 16:55
Letzter Beitrag: peter z 06
