Jau Super !
Dann brauche ich auch noch das Kabel der illumination control zum dimmen des Radios.
Edit:
Radio C1
|xxxxxx||xxxx|
10................1
1 - Gray - Speaker Return-LH Front
2 - Tan - Speaker Feed-LH Front
3 - Dark Green - Speaker Return-RH Front
4 - Light Green - Speaker Feed-RH Front
5 - Black/White - Ground
6 - Pink - Radio Signal-On (Coupe Only)
...... * (Powers the Radio Antenna Module/Diversity Antenna Relay. I measured 5 Volts coming out of the stock radio to power the RAM. I cheesed out and fed it 12 volts - and that seems to work - but do
this only at your own risk!)
7 - not used
8 - Dark Green - Power Antenna and Amplifier Relay Feed-Coil (With UZ6)
...... * (The relay chooses which antenna to use: Front/Rear. I measured 12 Volts coming out of the stock radio when it chose the 2nd antenna.)
9 - not used
10 - Orange - Battery Fused Feed
Radio C2
|xxxx||xxxxxx|
20................11
11 - Brown/White - Remote Radio Signal-LH Audio (With UZ6)
12 - Dark Green/White - Remote Radio Signal-RH Audio (With UZ6)
13 - Black/White - Remote Radio Return-Audio (With UZ6)
14 - not used
15 - Dark Green - Entertainment and Comfort-Data Buss
16 - Orange - Serial Data
17 - Light Blue - Speaker Return-RH Rear
18 - Dark Blue - Speaker Feed-RH Rear
19 - Yellow - Speaker Return-LH Rear
20 - Brown - Speaker Feed-LH Rear
Radio C3
|xxxx|
1....4
1 - Dark Green - Audio Signal-Conditioned-LH Front
2 - Light Green - Audio Signal-Conditioned-RH Front
3 - Brown/White - Audio Signal-Conditioned-LH Rear
4 - Black - Audio Signal-Conditioned-FH Rear
Radio C4 (CD Changer)
|xxxxxxxxxx|
15..............7
7 - Yellow - Audio Return-Conditioned Common
8 - Bare - Drain
9 - Tank/Black - Audio Signal-LH Front
10 - Light Green/Black- Audio Signal-RH Front
11 - Brown - Audio Signal-LH Rear
12 - Dark Blue - Audio Signal-RH Rear
13 - Light Blue - Audio Return-Common
14 - Bare - Drain
15 - Black - Radio Ground
Mike
